When I add a new printer in Windows Server 2012 R2, I’m unable to print to it directly from PlanetPress Connect Designer and receive the following error message:
“LoggedApplicationException: There was an error running the output creation process caused by Can not use output Destination: Exception: Can not use output Destination: Windows Printer : (P) (SRV000114) (SRV000114)”
If I restart the print spooler, I no longer get the error message for that printer, but, any new printers I add since the print spooler reset will not work unless the print spooler is reset again.
Example
-Add “PrinterA” to Windows
-Print to “PrinterA” in PlanetPress Connect Designer via Print Wizard using Output Type “Windows Printer”
-Error message appears.
-Restart print spooler
-Page prints without error
-Add “PrinterB” to Windows
-Print to “PrinterB” in PlanetPress Connect Designer via Print Wizard using Output Type “Windows Printer”
If I select the checkbox for “Output Local” in the Output Options section, I receive a error message "Error: Windows Printer : (P)
Seems there’s a sort of restriction in place to access this printer, because the error SRV000114 points to a permission issue. I got the same error code a while ago with printing a PDF to a shared drive.
Is that a shared network printer maybe? That would explain the error with the “Output Local” option as well.
