I have done the same. My Designer and Server are both on the same machine. Everything is using the same account and it is a local Admin. I’m also logged into Windows as that account. I tried to print through another Connect Server machine within the network and get the same error.
The script posted is not the real script I’m using. In the real script I read data from loaded CSV, load data from a second (external) CSV file and combine both files based on one field and write it to a temp file and use that temp file as input data. In the datamapper everything’s fine and in the designer I can access all fields and records. Only at PDF output through the server I get an error.
If I save my combined data (loaded CSV plus external CSV) in a new external CSV file the external file will be filled correctly and if I use that new CSV file in another datamapper I don’t get an output error.
Note: I’ve tried it again on two machines (Connect Version 1.8 and Version 2018.1.1). With Version 2018.1.1 it works fine. With Version 1.8 I got an error (error message below). Without changes I tried it again with Version 1.8 (only click again on Print) and it worked as well without any problems. Now I’m confused…
Error creating copy of Data File “C:\PLANETPRESS\FUNKTIONSTESTS\MEHRERE_DATENQUELLEN\QUELLE1_KDNR.csv”. C:\Users\Thomas\Connect\filestore\inputdata.6187364500167156052.csv (DME000056).
java.lang.Exception: Error creating copy of Data File “C:\PLANETPRESS\FUNKTIONSTESTS\MEHRERE_DATENQUELLEN\QUELLE1_KDNR.csv”. C:\Users\Thomas\Connect\filestore\inputdata.6187364500167156052.csv (DME000056)
at com.objectiflune.datamining.DataMining.a(DataMining.java)
at com.objectiflune.datamining.DataMining.initialize(DataMining.java)
at com.objectiflune.datamining.ui.model.DataMiningModel.generateContext(DataMiningModel.java)
at com.objectiflune.application.designer.editors.TemplateEditor.doPrint(TemplateEditor.java)
at com.objectiflune.application.designer.perspective.internal.handlers.b.run(b.java)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.objectiflune.application.Application.start(Application.java)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.nio.file.AccessDeniedException: C:\Users\Thomas\Connect\filestore\inputdata.6187364500167156052.csv
at sun.nio.fs.WindowsException.translateToIOException(WindowsException.java:83)
at sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:97)
at sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:102)
at sun.nio.fs.WindowsFileSystemProvider.newByteChannel(WindowsFileSystemProvider.java:230)
at java.nio.file.spi.FileSystemProvider.newOutputStream(FileSystemProvider.java:434)
at java.nio.file.Files.newOutputStream(Files.java:216)
at java.nio.file.Files.copy(Files.java:3016)
… 30 more
