Error when Package File
Hello!
I am trying to connect a Designer Template and accompanying DataMapper to OL Workflow by clicking on Package File.
However, I get the following error:
Get Presets- Cannot access the repository: URI has an authority component”.
What is this error message trying to tell me?
Are you running the software from a local drive or from a shared drive?!?
I am running OL Connect on my company laptop and this works OK for OL Workflow but not for OL Connect Designer/Server/MySQL.
I have tried installing OL Connect on a separate and non-company PC and there everything works fine and the software doesn’t take 15 minutes to start up as it does on my company laptop.
I think the issue is the fact that I am trying to run OL Connect on my company laptop, and I have no control over this. In fact I have had issues before when programming abroad that it will take several minutes to compile code because it is compiling over the internet on a network drive located in my home country.
Sincerely,
Marcus
I am assuming your home directory is on a WebDav drive. I am not sure what could be causing the exact issue - it seems to be a problem with credentials - but can you tell us if you’ve encountered the same kind of problem with other applications (besides your issue with compiling code) and whether it occurs when your laptop is docked in your home location.
