Hi - below is an error message I am receiving. Does anyone have any ideas why?
W3001 : Error while executing plugin: HTTP/1.1 500 Internal Server Error LoggedApplicationException: There was an error running the output creation process caused by ApplicationException: Component ‘AdditionalText_1’: Problem while adding text [�], character [\ufffd:0xfffd] is not present in font ‘NimbusSanL-Regu’
(SRV000042) Create Output: W1603 : Plugin failed - 08:32:50 (elapsed time: 00:00:01:037)
I have one branch with a data mapper and set properties plugin then I have six other branches with six different templates with pdf output. I am trying to use the retrieve items on each of the six branches.Then a process to merge them into one final pdf. Maybe my set properties and retrieve items are not set up properly? Any insight would be greatly appreciated.
