I have issue, my client requires a report email of the each process, I have 8 workflows and each flujos have 8 flujos within, how do generated report? is possible?
The config.cfg file found at C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch is an XML file. You could setup a process that load it as your input file and build your Template with it.
Granted it is not very easy to understand but is feasible.
