Yes I will share data mapper and template with You.
Doesnt matter if its table of div for me.
@Erik help me with this, but the problem here is now that if we remove break lines using post function and regex then it doesnt looks same like on the input.
Is there any way to assure that if we extract data in data mapper on input, then we will keep the same text appearance/formatting in template?
Ok, first I couln’t reproduce your issue as I got an error on record 13 which was due to your Delimiters before/after being equal to 1 when it is supposed to be 0.
The problem is that your dynamic table is made of 1 field (cell) that is too big for the page. I have received confirmation that cannot work. You’ll have to rethink the way you map your detail lines, each into their own subrecord if you want to get it to work.
Migth I ask why you did it that way instead of reading each line of the data into their own subrecord?
At this point, you’d better contact our technical support team. They will be able to review what you wan to do and guide you in how to do this. This channel isn’t the proper to rethink and redo your Datamapper.
I think i was able to work around this with Your help.
So now I can fit all my detail when I decrease the font size a litle and also line height and there are no format change on input as Erick suggested and it seems to work ok.
I have some another questions but i will create new thread for that.
If you go the route of decreasing your font size, make up a data file which fill up to its maximum, all lines in your data and test it with it, so you don’t endup in the same position in the future.
