Dynamic Images wont retain position
I am trying to make a dynamic image box that keeps the original aspect ratio of the images but also keeps the center point of the image in the same position. Currently when I try it each image appears in a different spot on the page, close to each other but not the same position. I am not well versed in CSS or HTML but trying to learn as I go.
Hi mfrankli,
Have you try to use or insert positioned box, it works on dynamic image.
Below url explain box element used in Connect.
https://help.objectiflune.com/EN/pres-connect-user-guide/2019.1/#designer/Elements/Boxes.htm?Highlight=position%20box
Hope this help, thanks
Best Regards,
Rostam Romainoor
