Dynamic hyperlink in email
I’m trying to do a simple thing
I have a csv file with two fields
first one is an email address, second is a hyperlink (different every time)
For each record, I want to send the hyperlink to the email on the same line
I’m not a programmer so is there a quick solution ?
Yes, there is and no programming is needed.
A 3 steps PlanetPress Workflow process:
1- Input (well wherever your data is coming from)
2- Change Emulation plugin set to CSV (you will find it in the Action tab)
3- Output -> Send Email plugin found in the Output tab.
Once you are in the Send Email plugin, fields which have their name in marroon means that you can have a dynamic value there. Right click in any of them and choose “Get Data Location” and select your field.
Of course, make sure you have a valid data sample to use at the time as well for step 2 and 3.
Keep us posted.
