Is it possible for me to configure Output Preset to create the output in a Dynamic folder name.
I can rename the file using my metadata with no problem through “Output Mask”, but is it possible for Output folder as well?
Many thanks
Many thanks
Please check this link: https://learn.objectiflune.com/en-gb/planetpress-connect/howto/variable-directory-in-output-preset
Thank you for your reply.
Well, I found that workaround, but I can’t quite Make it work.
How can I use the workflow to set the output folder name?
Use the Set Job Infos and Variables to set the value of one of the JobInfos (1 to 9) for this effect. Use double backslashes. Ex: C:\Project\OLConnect\Project1\OUT
Use @automation.jobinfo9@ in your output preset and in workflow use the Set Job Infos plugin to set job info 9 to whatever folder name you want to use.
EDIT: Oh snap @Rod.
Thanks Guys. It worked !
Glad you got it going!
