Docuware Connector
Is the Docuware Connector compatible with PlanetPress Suite v7?
There are several different methods of DocuWare integration available other than the plugin.
If PlanetPress Imaging is available, then the PDI file it can produce with a document can be natively read by the DocuWare Import module. Field names, etc. must match exactly between PlanetPress and DocuWare.
DocuWare Import also has an XML specification for importing metadata along with a document. Here’s a good starting point for understanding that spec. Home  · DocuWare Support Portal
(Note that DocuWare Import requires an UTF8 encoded XML file so the normal “Create file” plugin doesn’t cut it for this purpose. Build the XML file via a script instead to enforce the encode.)
Hope this helps!
I believe that the Docuware Connector is only compatible with PlanetPress Connect. If Docuware export is required with PlanetPress v7 then an alternative method such as Home  · DocuWare Support Portal is required.
