Do not want last value to show in dynamic table
Hi - I have dynamic data in a table. I have 6 values. the last value is ‘All’. I do not want to show that value in my table. I have a script I am trying to use but it isn’t working.
Am I close at all?
results.each(function(index){
var ageCnt = record.tables[“BalByAge”][index].fields[“pls_ageCnt”];
var field, result = “”;
for (var i = 0; i < results.length -1;i++)
field = ageCnt;
if (field != "") result += field;
this.html(result);
Thank you!
Try:
if (field != "" && field !="All") result += field;
That helped me - thank you!!. I just had to tweak it a tiny bit but it works now.
