how to change dinamicatly an image in desing depending the white space available, for example: if i have 4 whitelines use image X if I have 10 lines use image Y.
Hello aguzman,
You can easily use the built-in “Whitespace” feature in Connect Designer to do this. Essentially, you add both images to your document, each within their own paragraph. In the paragraph settings (Attributes pane while it’s selected) you check the “Whitespace” option. This option will basically add an image if there is enough space - if the largest image is placed first it will have priority. If there is space for both images it will place both, if there’s no space it won’t place either.
You can see a video tutorial on it here: http://learn.objectiflune.com/en-us/planetpress-connect/designer/print/whitespace
Cheers,
~Evie
