I have text detail data that is comprised of one or more detail data lines followed by a summary record:
detail
summary
detail
detail
detail
summary
detail
detail
summary
What would be the best way to handle this in the data mapper?
detail
summary
detail
detail
detail
summary
detail
detail
summary
If this is a text file, set it to read 1 line/record at a time.
In the Boundary section, set the boundary on presence of the text “summary” (at least for the example you posted, this would work).
Then to extract your data, begin with a loop that runs “Until…” you see the text “summary”. Extract your details lines into a detail table inside the loop.
When the loop completes, you can add another extraction outside the bottom of the loop that extracts the summary line; set the Top Offset to “0” to pick up the summary line as that’s the line (current line) the loop will leave you on.
