Detail Data - Variably display content of the detail data
So I am trying to make a variable paragraph with the content from the detail record set.
blah blah blah, @Detail1@ and @Detail2@ and @Detail3@
However there could be any infinite number of detail records per record so this needs to be conditional, how do I go about this, I am new to PP and have been working with Printshop Mail for a number of years.
Liam
Think I have answered my own question, is this the best solution:
var text=“”;
for (i = 0; i < record.tables["detail"].length; i++) {
    if(i!=0)
    {text +=" and ";}
    text += record.tables["detail"][i].fields["FirstName"];
results.html(text);
Alternatively you could use:
var stringbuilder = [];
for(var i in record.tables["detail"]){
    stringbuilder.push(record.tables["detail"][i].fields["FirstName"]);
var text = stringbuilder.join(" and ");
results.html(text);
Or use:
     stringbuilder.push(record.tables["detail"][i].fields["ItemNumber"]);
results.html(text);
The join() method joins the elements of an array into a string, and returns the string. The elements will be separated by a specified separator. The default separator is comma (,).
