Hi All,
I got some errors when reading some pdf files. is there any method to fix below problem ?
Under the below cases, i can open pdf from browser and copy content to notepad correctly.
for case 2, cannot preview the pdf on pdf viewer under connect designer.
thanks.
case 1
case 2
got error “Unable to open the document 1 (DME000049)”
below is the detail error message:
ERROR [30 Nov 2019 12:29:48,876][main] com.objectiflune.datamining.ui.model.DataMiningModel.loadDocument(DataMiningModel.java:-1)[COMPONENT=Data Mapping][SOURCE=Internal] Unable to open the document 1 (DME000049)
java.lang.Exception: com.objectiflune.datamining.pdf.pdfengine.textextract.TextExtractorException: Error while retrieving character data (DME000165)
at com.objectiflune.datamining.ui.model.DataMiningModel.loadDocument(DataMiningModel.java)
at com.objectiflune.datamining.ui.model.DataMiningModel.setDocumentIndex(DataMiningModel.java)
at com.objectiflune.datamining.ui.model.DataMiningModel.updateDocumentCount(DataMiningModel.java)
at com.objectiflune.datamining.ui.model.f.run(f.java)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:37)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4213)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3820)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at com.objectiflune.application.Application.start(Application.java)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
Caused by: com.objectiflune.datamining.pdf.pdfengine.textextract.TextExtractorException: Error while retrieving character data (DME000165)
at com.objectiflune.datamining.pdf.pdfengine.textextract.internal.WeaverExtractorEngine.analyze(WeaverExtractorEngine.java)
at com.objectiflune.datamining.pdf.data.PDFDocumentData.analyzePage(PDFDocumentData.java)
at com.objectiflune.datamining.pdf.data.PDFDocumentData.reset(PDFDocumentData.java)
at com.objectiflune.datamining.pdf.data.PDFDocumentData.open(PDFDocumentData.java)
at com.objectiflune.datamining.Document.open(Document.java)
at com.objectiflune.datamining.ui.model.d.run(d.java)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Caused by: com.datalogics.PDFL.AdobeLibException: The encoding (CMap) specified by a font is missing.
at com.adobe.apdfl.AdobeJNI.PDPage_acquireContent(Native Method)
at com.adobe.apdfl.PDPage.acquireContent(PDPage.java)
at com.objectiflune.apdfl.binding.Page.getContent(Page.java)
at nl.edmond.workflow.components.readpdf.ReaderPage.acceptContentVisitor(ReaderPage.java)
at nl.edmond.workflow.components.extracttext.textextraction.ExtractorImpl.getPage(ExtractorImpl.java)
at com.objectiflune.extraction.client.local.internal.WeaverExtractorLocal.executeExtraction(WeaverExtractorLocal.java)
at com.objectiflune.extraction.client.local.ExtractionLocalClient.a(ExtractionLocalClient.java)
at com.objectiflune.extraction.client.local.ExtractionLocalClient.getPage(ExtractionLocalClient.java)
… 7 more
