Is it possible to write the current folder name in job outputfolder + add a folder with current date?
I want to do this in designer because whe have alot of adhoc jobs.
I think this isn’t possible as you cannot use variables in the Job Output Folder field of the Print Options and the folder needs to exist (it won’t be created by Connect if not existing).
So best you have a fixed local folder, or use Workflow which provides much more possibilites.
