CSS border for field creates vertical line through all fields
Howdy,
I have the following code class connected to a field in Connect Designer to conditionally create a border around a field, this seemed to work well in the past:
var field;
field = this.record.fields.Field_InventPickingListTrans_SalesQty;
if (field > 1.00)
this.css(“background-color”,“#c0c0c0”);
this.css(“border”,“1px solid black”);
For some reason it is creating a vertical line through all fields in the following example:
When I comment out the code in the class the vertical line goes away, along with the field borders.
Has anyone else experienced this?
Thanks!
The solution to this was to apply a code class to the repeating field that just had a dash “-” in it.
Once I did that the vertical line went away. So I’m guessing it was using the css from the field above -ish?
Enjoy!
