Odyn
1
Hello
I have trivial problem with my document cover page
I would like to add 1 sheet (duplex page at the beginning of document). It works fine, i have 2 sides inserted before each PDF file batch
I would like to stamp two different words on 2 different sides. Lets say that we have:
Word “FRONT” stamped on first side
Word “BACK” stamped on second side.
I have one master page and one print context for cover page.
its not working as expected. Can You guys help me?
How to add 1 word on side 1 and other word on side 2?
Greetings
Already tried with two master pages? One assigned to the front, and one to the back page.
Odyn
3
Nope
I just figured out the solution
I can use two different page media anchors like:
for FRONT
for BACK
Rod
4
Create two master pages named CoverFront and CoverBack and add the text\content you need on each master page.
In the Sheet Configuration of your Cover section:
- Set the section to Duplex
- Under the Single Sheet section, Allow content on All sides and select the respective master pages for front and reverse of the sheet.
Odyn
5
This is also good approach thanks
Odyn
6
Also the good way to solve this problem is to add text using output preset.
