I would like to create one mail with a dynamic table contains all records of the result of dataMapper.
But, I can create dynamic table only with table subset on each records…
Have you a solution ?
Thank’s for your help.
HH
HH
Hi @Herve_Heritier,
Can you please tell us what kind of data file you’re using? In case of for example a XML file you’ve the option to select on the Data Mapping Configuration side the option Use root element (Settings panel > Input Data). And after that you can use the Repeat step to create a detail table which I repeat “contains all records”.
Hi @Marten,
I use PDF as source and the better solution have found is to apply preference for splitting in the Datamapper to all pages and do a repeat loop to load fields into the record.
HH
