Connect workflow only processing up to 200 records after upgrade
Hello - i just upgraded to 2021.1 and now I seem to be having issues with files over 200 records. It stops. I have a process I have not had any issues with at all. Since upgrading the other day I have issues with it. Issues being it wont process over 200 records. Plus I get errors Create Job: W1603 : Plugin failed. It seems to be for anything over 200 records.
Does anyone have any ideas?
Thank You
Hi @ahaddad,
Can you let us know please from which version you were able to upgrade PlanetPress Connect to version 2021.1?
I had indicated 2021.1 but just double checked. In fact I upgraded to 2021.2.
Thank you
Hi @ahaddad,
Can you also let us know please from which version you have upgraded PlanetPress Connect to version 2021.2?
I’m sorry - I upgraded from version 2020
Hi @ahaddad,
So, after you have upgraded PlanetPress Connect from version 2020.x to version 2021.2 an error will occur each time you are processing 200+ records via a Workflow process, is that correct? Is this error message always the same and does it always occur by executing the same Workflow plugin? Does the error always occur by executing the Create Job Workflow plugin, for example?
Can you let us know please if you have multiple Workflow processes which processes data with 200+ records and if the reported incident does occur by multiple or all of these Workflow processes?
Can you also please share the entire error message?
