Connect and Enfocus Switch
Hello community…
Is there anyone out there using Connect Workflow and Enfocus Switch together via API ?
We use both applications extensively and I have started to try and get the two to work together, using Enfocus Switch for file onboarding, submission and job status functionality as well as a bit of preflight , and Connect to do its magic… passing files backwards and forwards using hot folders.
Both are really great tools, and love em both… I was wondering if anyone uses them and if so, have you had any joy with API’s ?
Many thanks in advance, no rush just a bit of a hobby project
Ollie
I don’t have any experience with Enfocus Switch, but glancing over at their REST API, interfacing with it should be fairly straightforward via the Workflow Scripting task.
Fetching info from a REST API looks something like this:
var xhr = new ActiveXObject("Microsoft.XMLHTTP");
xhr.open("GET", "http://www.example.com/rest/v1/fetchsomething", false);
xhr.setRequestHeader("auth_token", "!SOME_TOKEN!");
xhr.send();
var response = xhr.responseText;
Thanks Phil,
will have a play see what we can come up with, like I said its just a hobby project
Best Regards
Ol
