Connect 1.7 update eps images bug?
There seems to be an issue producing placed eps images in Designer, I get a red X in the position of the image when outputting to PDF, when I convert these to png the files appear ok… before the update my templates were working fine, whats changed?
Hi iBaldie,
I wasn’t able to replicate this issue. I had a document in 1.6.1 with an EPS image, then I upgraded to 1.7.1, proof printed a pdf of that document, and the eps image was still there. Can you give us more details about how you are using the EPS files? For example, are they images embedded in the document, or external images? Are you dynamically calling them, or just referencing them as static images?
Raphaël Lalonde-Lefebvre
