Checkbox with variable values
Hello Everyone :slight_smile:
I would like to add checkboxes to a form with variable values. For example, checkboxes for categories where they come from db or xml file. Those categories are variable.
How can I do that in the designer ?
Thank you
Regards
Tenalp
Iā€™ve tried to use this kind of script
function constructionLigneTab(i)
if (typeof(i)===ā€˜undefinedā€™) i = 1;
code = "";
code += record.tables.detail[i].fields.Item;
code += "";
return code;
The problem is with ā€œrecord.tables.detail[i].fields.Itemā€ where when I use ā€œiā€ Iā€™ve the error ā€œCannot read properly fields from undefinedā€. If I replace ā€œiā€ by a fixed value, it works.
Why Iā€™m not able to use a variable to get a value from a table ?
Thank you
Tenalp
