Hi all. We have a barcode requirement for a code 128 barcode in the format AA123456789. The barcode must start as subset B, and then switch to subset C after 1. In 7.6 I would achieve that by setting the barcode to be AA1^09923456789, but this no longer works in Connect. Can somebody advise how to achieve what we need?
I did quite a bit of digging and if anybody is looking for this also, the way to do this is:
- Make sure the barcode is compliant with what you’re about to force on it
- Set the subset to whatever the starting set is (not auto)
- Ensure process tilde is ticked
- At the position of the switch
- input ~d199 to switch to C
- input ~d200 to switch to B
- input ~d201 to switch to A
So, the value from the original post in Connect should be
AA1~d19923456789
I just love it when our users manage to answer their own questions and then take the time to provide that answer for the benefit of every one else. I truly appreciate the effort .
In this instance, I will ask our documentation department to add this information to the online help.
Thanks again for this, @puszczyk !
