Hi
On Connect Pres is there an option on Print Wizard where it can output for example 100 records in black and the final record is another colour?
Hi
The only way I can think to do this would be to preprocess the data in the Workflow. You’d need to read the metadata created by the datamapper to determine the final record of a set, then set a field value. The template could then read that field value and conditionally set colors in the form based on the value.
