Hey,
I have faced a problem. While I was opening the template connect has thrown an error:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ffcd1fff31d, pid=16400, tid=0x0000000000004a68
# JRE version: Java(TM) SE Runtime Environment (8.0_144-b01) (build 1.8.0_144-b01)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.144-b01 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [xul.dll+0x168f31d]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0000000002763800): JavaThread "main" [_thread_in_native, id=19048, stack(0x0000000000050000,0x0000000000150000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000000000000
And since then I get this error while running All in One plugin:
INFO [06 Nov 2018 15:21:35,502][Thread-21] com.objectiflune.datamining.engine.product.DataminingEngineThread.run(DataminingEngineThread.java) Can't connect to application, retrying (Dm_1725)
Can someone help? Thank you
