hello people, we have searched and we can not find the how.
We have a dynamic table, which has a column that is a barcode, we generate the dynamic table but we cannot make it show us the barcode.
can you give me some help with this.
Thanks a lot.
I’m not sure how much experience you have with HTML code and writing JavaScript code but from my point of view I suppose that it will be the best to:
- Create the Detail Table where one table column/TD-element contains the record field which contains the barcode value.
- Add a the barcode element to your Print Context section by Insert > Barcode > “Barcode type” (don’t forget to uncheck the option “Absolute”).
- Copy the HTML source code of the barcode element to use it in a Standard Script like for example:
Standard Script
Selector: table#example td.barcode
var result = "",
strDataParams = "",
objDataParams = {};
result += "<div data-params=\"@dataParams@\" style=\"width: 3in; height: 1in;\"";
result += "type=\"com.objectiflune.connect.addin.barcodes.code128\">@content@</div>";
objDataParams = {
"grayScale": true,
"textPosition": "BOTTOM",
"fontFamily": "Arial",
"backColor": "#FFFFFF",
"codeSet": "AUTO",
"showText": false,
"moduleWidth": 0.03,
"processTilde": true,
"scale": 0,
"fontSize": 8,
"barColor": "#000000",
"outputFormat": "PNG"
strDataParams = JSON.stringify(objDataParams).replace(/\"/g, """);
result = result.replace("@dataParams@", strDataParams);
results.each(function (index) {
var content = this.text();
if (content !== "") {
results.html(result.replace("@content@", content));
Please note that I’ve replaced the content of the data-params
attribute with the placeholder @dataParams@
and that I’ve added the placeholder @content@
to the content of the barcode element (DIV-element). And I’ve converted the content of the data-params
attribute to a JavaScript Object by replacing the "
values by a quote ("
) and adding the value to the variable “dataParams”.
At the end we will replace the content of each matching selector by the barcode element (DIV-element). We can do this by making use of the results.each()
function.
P.S. This JavaScript code has been written and tested in version 2021.1.1 of the Connect Designer
