append attribute to tr element using data from detail table field
How to add an attribute to the tr element with the value taken from a certain field in the detail table?
Example:
Design mode:
                <tr id="Transactions" data-repeat="">
                    <td class="data Transaction Date">@T2@</td>
                    <td class="data Description">@D3@</td>
                    <td class="data LCY">@C7@</td>
                    <td class="data Total_Used_Amount">@L5@</td>
                    <td class="data Category_Name">@T6@</td>
                </tr>
required output (source view):
                <tr id="Transactions" data-repeat="" class="Travel">
                    <td class="data Transaction Date">17/12/2017</td>
                    <td class="data Description">Expedia</td>
                    <td class="data LCY">850.00</td>
                    <td class="data Total_Used_Amount">1270.00</td>
                    <td class="data Category_Name">Travel</td>
                </tr>
                <tr id="Transactions" data-repeat="" class="Food">
                    <td class="data Description">Carrefour</td>
                    <td class="data LCY">50.00</td>
                    <td class="data Total_Used_Amount">1320.00</td>
                    <td class="data Category_Name">Food</td>
                </tr>
I tried the following script but it uses the same value of Category_Name (first transaction) for all the transactions:
var f = record.tables.detail[0];
results.attr(‘class’,f.fields[‘Category_Name’]);
Thanks,
farid
Try this:
Selector:_#table tbody tr_
where #table is the CSS ID selector of the above dynamic table
Script:
l>
results.each(function(index){
	let categoryName = record.tables.detail[index].fields.Category_Name;
	this.addClass(categoryName); ??
Thank you Rod, it worked perfectly.
Any idea why if I add .ToLowerCase() to the result I get the following error:
this.addClass(categoryName.ToLowerCase());
Error: Cannot find function ToLowerCase in object lease
Thanks.
JavaScript is case sensitive. Use _.toLowerCase():_
    let categoryName = record.tables.detail[index].fields.Category_Name.toLowerCase();
