All in one process using set.metadata in output preset
Isn’t it possible to use the All in one Task with an output and job creation preset defining the filenames (set.metadata.mymetadata).
When doing it in 4 steps it works, but using all-in-one I get a value undefined error:
W3001 : Error while executing plugin: HTTP/1.1 500 Internal Server Error LoggedApplicationException: There was an error running the output creation process caused by There was an error initiating to the output creation process caused by ApplicationException: expression ‘set.metadata.mymetadata’ at line 1, column 7 in pattern…
That’s not working with the All-in-One as you cannot provide a job preset where the metadata are defined.
