Additional text with Email Content
Hi all,
I’m currently using Email Content plugin to receive outputs on email, but I’m also using additional text on output presets to add text to a the design.
Is there a way to apply output preset setting on email workflow?
Can I ask what additional content do you want to add to the Email, that you can’t simply add in the Email Context of the Designer?
PageCount & PageNumber
I know they are available in the Designer, but they are causing me a problem with the details table. As if the detailed table is large ( +30 pages), the table start tl overlap over the header, and keeps going up each page.
I don’t have a explanation for this behavior, but it works normally when I remove the “Pagenumber” and “Pagecount” classes from the design.
Can you try adding the PageCount and Page Number in the Master pages?
That’s what I’m already trying to do.
Pagenumber comes in the header.
actually the problem is fixed only if one of these happened
  • removing the pagenumber
-modifying the details table borders!
Im using a “table-grid” but I configured the fields’ cells to have no bottom/top boarder, then I configured the table’s to have a bottom boarder, so I can have a line by the end of table on every page in the case the table is overflowing to next pages.
so when I modify the boarders back to normal the problem stop happening even with the existence of pagenumber.
This is the weirdest thing isn’t it?
