Gareth
March 23, 2016, 11:34pm
1
I am extracting data for a table in the Javascript of an Action step.
function ParseDocumentData(number, value)
var dataCode = value.substring(0, 4);
var dataDesc = value.substring(6, value.length - 6);
var x = record.tables.Data;//[0];
x.Code = dataCode;
x.Data = dataDesc;
Here “record.tables.Data” is a table which I created in the record, I want to add the new detail record to it.
Phil
March 24, 2016, 8:10am
2
You can’t do it this way. Fields can only be added through an Extraction step. So, your Action script should simply set a Record variable of type Object like so:
sourceRecord.properties.myObject = {Code:"123", Data:"456"};
And then your Extraction step can set the Code field to
sourceRecord.properties.myObject.Code;
Gareth
March 28, 2016, 9:55pm
3
Thanks, I got this to work now.
