Adding Postscript commands - LITREC
Hi
Is there anyway to inject PS commands direct into output like you used to be able to do with original PReS using the LITREC command?
James
there’s nothing similar to the LITREC command in Connect currently, but for the next version of Connect at least it’s planned to allow to add individual postscript code to the header of the ps spool.
Damn, ok no problem. Back to the drawing board then
