I have a job where I’m getting PDF input along with a XML index file. Some of the PDF’s will be simplex but I need to make everything duplex so I need to add a blank page between each page on the simplex PDF’s. Whats the best way to go about this?
Regards
James
Hi
Sorry didn’t make myself clear. My XML file will have a flag for simplex or duplex but everything will be printed duplex, so if a record comes in where the data says simplex I need to add a blank after each page so it only puts the pages on the front.
James
That is exactly what this option does. Duplex will be duplex and simplex will be duplex with a blank back.
That will only do it for the last sheet.
For example if I have a 3 page PDF, I want the output to be 6 pages:
Input Page 1
blank
Input Page 2
blank
Input Page 3
blank
and within the same run I may have some duplex records that don’t need this doing so need to be able to do on a record by record basis
Not only last but also any simplex page
Ah right so how do I set if a pack is simplex or duplex then?
You dont have to, it will auto-detect the simplex pages
Hi
I don’t see how it will know as the document could be 2 pages but it needs outputting as 4 pages. Within 1 run I could have a 2 page simplex and 2 page duplex pack and would need to output as:
1 - Duplex PDF Page 1
2 - Duplex PDF Page 2
3 - Simplex Page 1
4 - Blank
5 - Simplex Page 2
6 - Blank
If that makes sense?
