Adding a Barcode to a PDF Input Job
Hi
I have a job which is a PDF input and I need to add a 2D barcode with a UID to the first page in each pack. I appeared to have this working but within the template but some of the PDF’s don’t have a transparent background so the bar code appears to be getting covered up. Is there a way to make this always appear at the front rather than back?
James
Make sure your PDF is set to the background of the page.
See https://help.objectiflune.com/en/pres-connect-user-guide/2020.2/#designer/Print/Print_Sections.htm#Using_a_PDF_file_as_background_image for more information
As Phil has already written, it is best to include the PDF as a background PDF.
If for some reason this is not an option, the barcode element (div) can be assigned a higher z-index if necessary (via CSS, JavaScript or via the frame’s properties).
