Add data to a pdf file
I have some document print by system,
i want to :-
  1. capture it from winqueue input
  2. split by document number
  3. add a Letterhead to this document, and add a dynamic QR code to this (base on the document Number) to the document,
  4. then output it to a folder
i can do 1,2. when i try to add the letterhead to document by using designer,
the output is only contain the document which i use to create the template.
for example, i use a document (number 1234) to create the template. when i print out 15 different document, the 15 document only show 1234’s content. is there some sample on this kind of requirement ?
thanks in advance.
Hi @joeytsui,
Can you let me know please if the letterhead has been applied to the Virtual Stationary properties of a Media, as a background to a Print Context Section or as an image to a Master Page and/or Print Context Section?
Please note that, in case the letterhead has been applied the Virtual Stationary properties of a Media, you will also have to check the option “Print virtual stationary” on the Print Options page of your Output Creation Preset file. You can access the Print Options page by executing the following steps:
  1. Open the Connect Designer application.
  2. Go to: File > Print Presets > Output Creation Settings…
  3. (optional) Select a existing Job Creation Preset and Output Creation Preset on the Configuration Selection page of the Output Creation window.
  4. Click on “Next >” to go to the Print Options page.
  5. Check the option “Print virtual stationary” on the Production Options page.
Please note that these steps are only required when the letterhead has been applied the Virtual Stationary properties of a Media and you would like to print digital output.
thanks, i make some mistake, ok now.
